Two other fairly common sources are the little connector hose on the pass side above and behind the turbo agaisnt the block. It is only a couple inches long, wrapped in shiny heat tape, check the clamps.
The other is the back freeze plug on the drivers side, this requires looking from underneath with a light right up under the intake.
