DaveHess
I need some help! About a month ago I changed out thermostat, radiator cap, and coolant replacing them all and the coolant with Zerez G-05. I had no issues and the truck ran where it always has on the temp gauge, just below the center mark. Two weeks ago, I began a trip to Colorado out of North Dakota with my TT and I noticed the temp gauge was a tad over the center mark. I decided to just keep an eye on it since the amient was at 90 and higher. By the time we were rolling through Wyoming, the temp gauge was over top the second zero of 200. Again, I decided to just monitor since the owners manual calls this the "normal range". When I got to the campground outside of Denver, I checked the "status" of my coolant and found I was "heavy" to the coolant and light on the water. Meaning I was way over 50/50 mix. I drained it and redid my mixture and got it to 50/50. I thought I had corrected my problem. I also did not get a CEL at any time. A week later we started back to ND and had the same problem. Luckily we caught a cold front and rain for a large portion of the second day of travel and that helped keep things a little cooler.
Upon my return, I put the "Hawaiin Stat" back in to try to keep things cooler and also found using my Smarty Jr, I had code P0483 (Fan Speed). I reset the code. When I ohmed out between pins 2 and 3 (sensor and ground), I get an open and between 2 and 5 (sensor and 5v), I get an open on the wiring connector to the fan clutch. Am I doing this right? When I try to spin the fan by hand, the most it will spin is about 1. 5 turns and that was after multiple spins. The initial spin only moved about two blades widths. I also pressure checked the new cap and it held between 15 and 16. I pressure checked the pickups cooling system and it held as advertised. I took the truck on another trip this weekend with the TT and without the stat thinking it would run cooler and this would be better than running as hot as it did going to CO. It still ran a tad over 200 degrees and this time did not set a P0483 code. I understand that RPM would directly affect the cooling with the stat removed so I slowed to 60 MPH on this trip. What did I do or am doing wrong here??? I have a Cummins 190 stat on order to replace the Gates stat that I took out. I am at a loss here. The radiator appears clean and there is nothing between (debris) the coolers. I do have a screen on the front and have done this for years without issue. Please help!!!
