I'm in the process of chasing down a brake fluid leak - I've added about a pint of fluid over the last 3 months. The right rear wheel was suspect because of some sort of leak. Turns out the leak was gear oil caused by what apears to be a rear seal that was installed backwards. So for a sanity check, I have a couple questions... .
1) Should the hub seal be installed so that the lip faces outboard, i. e. , towards the bearings vice towards the brake shoes?
2) Are the hub bearings lubricated with grease vice gear lube? When I pulled the axle shafts an ounce or less of 90 wt was in each of the bearing cavities but any signs of axle grease were not apparent on the bearings.
3) Does the presense of gear oil in the hubs indicate an over full condition?
Thanks for the help!
