I headed out this weekend for a camping expedition. After parking the truck for a few days, I noticed a sticky mess on the ground toward the front, right side of the truck. I could not tell for sure what the substance was other than sticky. I thought it might be coolant, I did add some coolant to the truck before leaving. That was unusual. The truck seemed to run fine maybe a touch hot (5 or 10 degrees) nothing outrageous. Now that I am home and parked the truck for 2 minutes the truck is leaking pretty good. I have also picked up a slight squeal coming from in the engine compartment that I can't identify. I threw a pan under the truck to catch the fluid. So the question is there any way the water pump could be going bad on an '03 with 120k miles????:{
