Was driving to a gun shop to pick up a gun I had ordered On the way there I get a ding ding and the cel comes on. When I get to the store I use my edge insight to see what was up. I got two codes
P203F which appears to be a def related code Reductant Level Too Low which is odd since there is just under 1/4 tank of def in it at the moment. I have received this code one or two times in the past shortly after I refilled the tank but has gone away on its own very shortly
P020A which seems to be some sort of injector timing code. malfunction in the injection timing circuit for a particular cylinder of the engine If I was reading correctly it would be cylinder 1
Not sure if one was already stored or if they both came together this morning as cel had not been on previously. Either way truck runs fine def is 1/4 full. starts, runs fine etc I was a decent diagnostician on my 01 but the 2017 have little clue with all its new fangled computer stuff. Mostly concerned about the p020a code. Truck has 128k on it so far and seems to run fine. By the way I did clear the codes and went about my business this morning and it has not returned since, at least yet but only another 20 miles or so of driving so far
If anyone has seen this before, has advice etc am all ears TIA
