I'll get to the point:
I thought the VA C3. 1 would be the best stack with the TST because it tapers off on the high end and I thought that would let rail build better PSI, etc (as opposed to the EZ which uses PSI all the way through the RPM band)
Well, the dyno shows differently...
VA/TST - max of 476 hp (I tried both levels)
EZ(lvl2)/TST - max of 524 hp
The graphs look the same until about 50mph, the VA graph starts to fall off, the EZ graph just keeps climbing
Anyway, not to dog on the VA, it felt AWESOME on the street, really awesome down low... But when the chips are down, the tapper'ed top end gives up HP...
As for the NITTO review... because of the "d" rating, I will not be purchasing them again. I can feel them squirm under the truck in crazy heavy turns, and in heavy acceleration...
Its nothing too bad, But it is certainly not there when I put the stock tires back on...
