Nothing is impossible! But HB pointed out the obvious limitations of that set of tires for towing a heavy 5th wheel. Yes, that tire may have a rating that meets or even exceed the stock size tire but the additional mass between the rim and contact of the road surface is where stability derives from. A taller tire will NEED that added cushion of weight rating when combining them to the towing prowess of a stock size tire. And that's not even factoring the additional rotating mass that the brakes have to overcome while stopping unloaded... . now add a 14k toyhauler with a 3500lb pin weight. A simple way of looking at it is this: As an example a truck with a 3. 55 axle ratio is rated by Dodge to tow 16k. But a truck boasting 4. 10's is rated to tow much more. Well?..... tire size affects final drive ratio right?
I agree though... Harvey can be a little harsh at times and I have had issues before with him just as many others have had. But he is right many more times than he is wrong and his experience precedes him..... and I do my best to respect that. The guy cares about your safety... . there are way too many people that really don't care anymore and he does! The OP asked for advice and he got it..... simply put! I asked the very same basic question 3 yrs ago and he gave the same very advice..... and about as harsh as he did with this OP! I didn't listen and bought my RV anyway - a 40 ft. toyhauler. I spent the next several weekends upgrading my truck to pull the RV and 'thought' the truck was much better suited to do the job..... which it was. But the inherent weaknesses soon show their ugly heads as time passes! Each and every one of HB's examples of my truck not being sufficient enough showed up in my future as I continued to use and tow my rig.
Take this post for FWIW..... but it sort of reminded me of being a hard-headed teenager with a know it all attitude and sometime into your early 20's you eventually realize that ... . Damn..... that old man of mine was right after all!
