Details here: TDR Privileges
I am trying to locate and clean the cowl drains on my 2006 Quad Cab. I park near pine trees and suspect the drains may need cleaned. Any help locating the drain exit points would be appreciated.
They are a slot on the outside of the cowl panel. It has been a while but I think you have to remove the plastic cowl grille to get to them. Some had a rubber flapper covering them up.
You would also have to check the fenders down near the rocker panels (may have to actually unbolt) as that is a great breeding ground for collecting leaves, pine needles etc. and causing rust issues.
