You're right, pm sent.
Tom
Tom
Tom,Here are the symptoms, start cold, drive for 4 to 6 minutes then tach dies and 2 seconds later I lose power (not limp mode I think, I can still go 70 or so but not uphill and very little acceleration) then 4 or 5 minutes and tach comes back, 2 seconds later power returns and all is fine until the next cold start.
Tom,Tach stays on zero the entire time of low power. I agree it seems to be heat related, as for the wiring being checked thoroughly, I can only take his word on it, but it just doesn't sound like wiring because it is so predictable (see previous post). As for pins on the ECM, this is the second ECM with the exact same symptomsThis one is beyond me. Thanks again for all the brain power going toward my problem. It is a 6 speed 01. I haven't noticed any smoke but I really haven't been looking for it. When I go home today I'll check for it.
From what I know of how code scanners work... you would indeed need the Chrysler DRBIII tool for this level of diagnostic work. A simple code scanner can only pick up data present on the OBDII data bus, and that wouldn't include the camshaft and crankshaft sensor inputs and outputs you're looking for. The DRBIII on the other hand is capable of reading all communications being sent over the CCD (Chrysler Collision Detection) bus, and it can send out signals over the CCD bus to control the various vehicle computers.Does it have to be a "Chrysler" scan tool?
What??? I thought every 2nd Gen 24v Dodge Cummins owner carries a DRBIII in his truck... along with a spare VP44, an ECM, and a PCM! :-lafYIKES! Never mind about buying one
Tom,I thought I saw a link somewhere in this thread for a PCM source, maybe it was somewhere else but does anyone know of one? I'm taking it to the dealer soon for diagnosis only and want to be prepared when I get the "good" news. Thanks again for all the help.
Barry,However the ecm they sent me the other day threw more codes than my existing bad one, it also was fairly dirty ie the plug connector had oily dirt on it so it hadnt seen a plug in some time.
Barry,One of the codes was an apps irrationality which would explain the new dead pedal issue...
Tom,Barry,
I called the folks that sell the reman PCM and they are quoting more than there website advertises...
