My truck is finally back from the shop. About a month ago, I noticed a slight smell of coolant and couldn't trace the leak. After pressure testing my block, a 2" crack was found on the passenger side between two of the freeze plugs (FYI... 111,000 miles). I thought I was totally down and out... the dealer wanted me to spend major bucks to replace the engine. There was no way I was going to accept their response to swap the engine, especially since I expected to get 300,000+ miles out of my Cummins. In the end, after many phone calls, I was able to get Cummins to warranty the block... they basically provided a new (improved to resist this problem) short block and I had to supply $ for the labor. Unfortunate that I experienced the problem but, I'm happy with the end result... defintiely disappointed with Dodge's response.
Cutting to the chase...
What break-in process should I follow? I know it's better to load the truck for break-in (i. e. loaded break-in would be ~5K miles... . unloaded break-in period could be ~20K miles). Just looking for recomendations of what to do or not to do, so I don't hurt my investment.
Thanks in Adavance!
Thanks in Adavance!
