I have a 96 cummins 12 valve, I'm getting water in the oil, minor problem because the water is more steam and come out the breather pipe, nice creamy slime, I had the head off 6 months ago, leaking out in front of the thermostat housing and the shop said there was two cracks when he magnafluxed it, one was under the #3 exhaust spring and this appears to be where it is leaking. It wasn't leaking internally until after all the work was done, maybe the hot tank cleaned the crack out.
Any suggestion on how to fix this problem, block seal didn't work, I know another head would fix it, but has any tried welding a cracked head on one of these, or having one fixed, and is this a common thing or place to crack, any suggestion or info is helpful, or a good head cheap. Thanks for the help in advance, Chris
