I just pulled the head on my cousin's '97 this morning because it was starting to blow a tiny amount of compression into the cooling system. It has run for several months now with small amounts of coolant leaking into the crank case. We put in some BG stop leak and that fixed it for a while until now.
I replaced the gasket with the Marine version one year ago and about 40k miles of HARD pulling (up to about 36K GVW) over mountains and such. The engine has about 330 RWHP and has run at 1200º up many long mountain passes. The truck has about 175k on it now.
I did not see any sign of leakage from the crack area. I did however see in the gasket where it was blowing compression in a few spots in the front two cylinders. I did not have the head surfaced the first time around. It seems to be about . 008 low in the center when measured from end to end, which is within specs as far as I know.
I figure the head is probably junk but would like some opinions on where to do from here. If I for sure need to replace it where would be a good place to start looking? My cousin is really short on money so this is a really bad deal right now as I know heads are not cheap. Any advice would be greatly appreciated.
Mark
Mark
