When my manifold cracked, I dropped to my all time low of 9MPG, and a very dirty engine compartment!
Your peak/max boost might stay the same if you are up against the wastegate, but spool-up time will be longer.
The ATS manifold will definatly test your patience. To save on some frustration, replace those allen head bolts with some grade 8 bolts,, or, be sure to get a ball driver allen wrench (9mm)
You'll have a dandy time gettin' the heater hose how you want it,,, I just let my mount rest on the manifold.
My $. 02
Merrick Cummings Jr
EDIT: When you are ballparking 30PSI boost on an HX-35, your boost pressure/backpressure ratio start to be in the 1:2 range.
35PSI boost, is 70PSI back presure!
Think of how much air willl leak out with 70PSI pressure in the manifold.
