cracking sound from cowl
rear spring help for big cabover
More time with my RAM!
When i'm driving i'm hearing a cracking sound from the dash or cowl any ideas on what this is?
93'4+4 LE emerald green Banks PowerPack,Cummins chrome
John there is a TSB on this problem(23-63-94). Its listed in TDR issue 14. There is a stamped plate that is fitted at the base of the A-pillar. The cracks are drilled at each end and the plate is attached using rivets and a 3M adhesive.
Gene
92 350 4x4
I've done the repair and it is a pain. But worthwhile in all aspects. The crack has not come back since.
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
Hey John!
Please do a search for "Cowl Crack" before ordering the parts. I found that Chrysler has a part number mix up in their parts warehouse when I ordered the TSB part numbers. Both p/n's were for the right side and Dodge could not get the correct left side part to match the left side part number just 3 months ago.
"Gene H" had provided the correct p/n's in his informative post.
Just Keeno's experiences...
1992 W250 5spd. 3. 54 gears, LSD, JRE enhanced VE Injector Pump, BD High Output Injectors, Banks "Stinger Plus" consisting of a replaced 12cm2 wastegated housing, 3 1/2" JRE modified exhaust/muffler, pyro/boost gages, K&N, Skyjacker 2 1/2" front suspension lift to clear 305/70R/16 Goodyear MT's, Mag-Hytec, Amsoil, Rhino liner, Fully Chrominated Aluminum Aftermarket Accessory T-handle Shift Knob
John here are the pn's
Right side 4797019
left side 4797018
This seems to be more of a problem with the 4x4's.
It is a lot of work to put the plates on but it will fix the noise.
Gene
92 350 4x4
Thanks guys I appreciate the help. What happens if I don't do the fix?
