I have read a handful of threads but have not found this specific scenario yet.
2003, SRW, 2WD, manual transmission. Completely stock.
The batteries had been out of the truck for about 4 weeks while I was rebuilding the front suspension. The batteries were on a reconditioning charger.
Prior to beginning the suspension rebuild and taking the batteries out, the truck had been running fine.
Finished up the front suspension rebuild yesterday. Installed the batteries. Turned the key to the on position - low fuel light is on, volt meter never rises off its rest, fuel gauge never moves, check engine light stays on. It is suspicious that the gauges are not functioning. Grid heater does not run - light comes on then turns off quickly. But I never hear the grid heater's contacter close and open. The lift pump did not run - this is usually audible. So of course the engine cranks but does not start.
Knowing the fuel level was around an eighth of a tank 4 weeks ago, I put in 10 gallons of diesel. Still, the fuel gauge does not rise, the low fuel light stays on, the lift pump does not run, so of course, the engine cranks but does not start.
I have tried retrieving the codes using the key on / key off trick in 3 cycles and 4 cycles - I never get any codes on the odometer.
The next thing is to maybe buy one of those inexpensive scanners.
Any ideas?
Thank you for any help,
Paul Lohr
Any ideas?
Paul Lohr
