crank sensor
Black Smoke?
2005 surging idle only when rolling
Does anyone know the cummins and Dodge crank sensor part number and what they go for in both cases? I have a 2003. 6speed. Thanks.
bpenrod said:
Try a search, it should pop right up. If yours is bad I would think about the 2* advance model from rokktech.com.
i have only herd good about the rokktek but have not seen dyno numbers :cool:
I have not had mine on the dyno recently but it did smooth it out and make it more throttle responsive when I installed it.
Call the Cummins Dealer, they will look up the part number in ther system. The same sensor is used for both Cam and Crank on your engine. I bought mine for about $25-26 from Bridgeway Cummins.
