This is one area where my booster pump is very nice,after i change the filter, I simply crack the line on the VP44,since i have the rays banjos on it,and move the power wire on the relay from #87,to 87a-which is hot with relay not energized,with my drain pan under the truck, ilet the booster pump run about 10 seconmds,it will push all the air right thru the filter housing,after its all fule,tighten the line up,slip the connector back onto terminal 87,then fire it up. The first time did this,i forgot to move the fuel pump terminal back to 87,and when the relay energized,when it startedmthe booster pump shut off,I watched my fp guage go into vacuum,it was reading -4 at idle,i quickly shut down,and hooked it up right,I know for sure now if my booster pump quits,i cannot drive the truck,at all,it blocks fuel flow.
