Hello all, I have yet another question I would like some opinions on.
My truck just recently began to crank over slowly. Like it is really a struggle to roll the engine over.
Starter contacts????
I checked both the batteries and the one is at 12. 4 volts and the other is at 12. 9 volts. I did not check to see what the voltage is while cranking.
Alternator putting out 14. 2 volts at idle.
Anyone else experienced this situaton? If so, what did you do to remedy the problem?
I would also like to ask where is the cheapest place to purchase the fuel pick-up assembly that is located in the fuel tank?
I must have a problem with mine as when it gets down to about a quarter of a tank the truck will get air in the fuel system and will die. If I keep the fuel level over a half a tank it will not experience this problem.
Anyone ever have this problem either?
All replies welcome.
Dan.
Dan.
