OK, GET READY EVERYONE!!!!!!!
Went to the dealership on friday, NO pump in stock (269$),have it on monday we promise. So I went to CUMMINS WEST, 2 pumps in stock (145$)ea . Purchased the pump and also the trouble shooting and repair manual (69$). Also stopped by the local parts store and purchased a mechanical test gauge ,to test against the new autometer. Started the project after reading all the possible pressure tests points, and fuel problem scenerios. Tested all points with both gauges, same outcome!
: Time to replace the pump
. 20 minute job, as long as you've twisted all your banjo bolts 15 times in and out like I have searching for answers
So, next round of tests, all points,with both gauges. ... ... ..... You guessed it , same outcome ... ... ... .
Last thought , could the drop in pressure I am seeing, be due to the plug N power pulling too much for the lift pump to keep up with.
