CRAZY PROBLEM!
Truck ran fine this morning and in fact 2 minutes prior it started just fine to pull it into the shop. I shut it off and hooked up an exhaust hose to run it awhile and warm it up so I could chase down a coolant leak and went to start it and CLICK .....like a starter issue. I tried it again and no click. Tried it again and no power to anything inside. Let it sit for 30 seconds or so while I cjecked fuses and opened the door again and had power to the cab lights and all instrument panel worked but again a single CLICK with a turn of the key.
Now I have no power to anything except my quadzilla gauge that turns off and on with the key like it's supposed but nothing else. I also have a weird and fairly rapid click click click under the dash that is connected to the door light switch. If I push it in or unplug it it goes away but so no power to anything.
I checked all the fuses and they are all good. Both batteries are good. I am getting no ground coming out of the PDC. I have 12v at the red wire coming in but when i check voltage across them both I get 0. The big black wire next to the red wire should be a ground, right? And I should have power there all the time, right?
This issue makes no sense to me whatsoever.
Any and all ideas are appreciated!
'01.5 4x4 6spd 2500 QC LB -, hypertech
