Engine/Transmission (1994 - 1998) Cricket Sound from Eng.
Engine/Transmission (1998.5 - 2002) Moto Blue exhaust ???
Engine/Transmission (1998.5 - 2002) southbend con ofe opinions
Monroefiredog1
I have a 96 CTD, it sounds like a cricket is in the engine when it is running. I think that this is maybe the idler pully, or maybe one of the belt driven devices. Anyone had a simular problem? Any help would be greatly appreciatedMonroefiredog1@aol.com
My truck did the same thing when you started it then afted it warmed up a bit it went away. When I put the tab on my KDP I also replaced the orig. water pump afted that the squeak went away. Im guessing it was the water pump though it didnt seem bad once I got it off, it had 174k miles on it so you know wile your in there.
Sometimes a wooden dowell rod, placed between your ear and the suspect part can isolate the source. Kind of a poor man's stethescope.
Rog
My bet is the belt tensioner... . Take off the serpentine belt and check all your pulleys for deflection. Probably the tensioner tho.
good luck
-j
It could be the belt tensioner pulley. My Alternator kind of squeeks when it's cold out.
practical solutions.com had a nice steel belt tensioner w/ replaceable bearing. I don't know if they are stilll around.
