I had no intentions of doing it this quick, but after driving it right after the lift install the steering drove me nuts and the steering box was going bad.
I used Off Road Designs kit, when I called for the kit they would not send me the whole thing at once. They will send you the right side steering arm first so you can get measurements from the steering arm to the drop pitman arm. Which according to them was the same length as a chevy. I do recommend getting their drop pitman arm also. Its a 3" drop chevy arm with the same splines as our boxes so it will fit fine. The tie rod ends that are sent are to big for a Sky Jacker drop pitman and a reamer costs just as much as a new pitman arm.
I replaced my factory box with a new one from PSC steering (do right the first time). I used the factory plate on the back side to reinforce the frame. You will have to grind a good chunk off to make it fit inside the frame.
The attached pictures show the drag link at a hard right turn with the steering stops removed. There is plenty of clearence to be had. There are more pics in my readers rigs gallery.
I now have a 2 1/2" drop pitman arm, adjustable drag link, and sway bar lowering kit sitting on the floor. PM me if interested in the parts.
