2nd Gen Non-Engine/Transmission Crossfire Installation
2nd Gen Non-Engine/Transmission Brighter lights
I'm wanting to put some Crossfires on my 3500 dually. They are something that is popular in the class 8 trucks. They keep the air pressure equal between the duals and provide assurance that both tires are at the proper air pressure, at a glance....there's also a check ball in there that will cut off the pressure in the good tire in the event of air loss in the other tire. They also provide one spot to check or add air to both tires. My problem is that when I install it with the provided brackets, I can't get the center cap back on....I'm thinking of mounting it to the center cap with a different bracket. Has anyone put these on their 3500 with the stainless steel simulators? Any thoughts would be appreciated....
dualdynamics.com You can find a dealer in your area. You can also find them on Ebay or Amazon but I think I'd stick with one of their dealers. You can also choose what air pressure you want 75psi, 80psi and so on. So far, I haven't been able to figure out a good way to install them with the stainless steel simulators and center caps on my wheels. Without them, it's a snap....
