crown vic help
Are you an old time mechanic?
What is the difference?
Wifes 2001 crown vic has had the speedo and odometer in and out of service for months. Now its not working at all. I took the dash apart and found its a electronic type with no old style cable to transmission. Tryed replacing the speed sensor in trans and still no work and no check engine lite?
Anyone know of a good crown vic site like T. D. R so i can get some info to troubleshoot this?
The best thing to do is to find someone, even a good mechanic if you have to pay for time, get a scan tool, and there will be a way to watch VSS (vehicle speed sensor). This is the PCM's output. If it's steady it might be the cluster, but if it's not, you likely have a bad connection or wiring problem, which is my bet.
I'm sure if you google, you'll find a good crown vic, or general ford site to look at.
