Thanks. That's good solo mileage!
Attention: TDR Forum Junkies I wish someone would have told me this before I accrued 362k miles on my 2014.
It is indeed a miracle it made it that far....
I guess I’ll tow in 3rd exclusively with the 2018.
haven't you people long ago established that 342's are for fuel mileage because you really want a Prius but wouldn't be caught dead driving one of them, 373's are the best compromise if you can't make up your mind and 410's are only for you if you mean business.. and that using a Fram oil filter will kill your truck?![]()
Actually, what many of us know is that when it comes to moving a heavy load, it's:
good (3.42's),
better (3.73's),
and best (4.10).
It's almost as if Ram knew this too when they rated them for increasing loads as the ratio goes up (numerically).![]()
And as if I had a choice with a SRW, but after towing with 3:42's I wouldn't change anything with the load I tow.
I'm betting if you had the aISIN and a heavier RV you would not change!
I traded it in on the ‘18 4500.Did you sell your 3500?
I'll be towing my little 14' trailer behind us with the little Lance 855 in the bed. At about 17000lbs total can I use CC and not worry about it, on normal non mountainous roads? It seems to hunt at 70mph over slight rolling hills.Watch the trans temps?With the Aisin, 65 is when it will shift to 6th with 3.42 gears. RPM would be pretty low for towing. Like 1400-1425 RPM.
