cruise control Auto to nv4500
exhaust brake rattle??
Test drove some new trucks
Since I changed from automatic to a nv 4500 my cruise will not work. I assume the wire plugs that went to the auto. may be the problem since they are disconnected. Anyone know how to get cruise working with the nv4500.
How did you hook up the neutral safety switch on the clutch if you used the plug under the dash unplug it and run the center wire that was plugged into the auto to one of the wires on the switch on the clutch cyl then put the jumper that you took from the plug under the dash back in to complete the conn. if you dont understand this call me and I will explain it better on the phone. 530 938 3427
