Do NOT take it to the stealership, much bucks! You should get what you need here. Check hoses to actuator under the drivers side battery. They get eaten up. This is vacuum operated so a vacuum leak will ,do it in. If you lose power at the on/off switch at the wheel it will also go. You need a wire diagram for that . If you don't have someone here will. The clock spring will also do it as sometimes it is too short and pulls wires loose due to strain on the harness. Do a search on this site and you will get a ton of help. Good luck!!
