Well we changed to the 3k governor spring and did some more work on truck! Installed the 16cm housing! Well here is the problems we encountered-need a air gap setting number for the crank position sensor. Also the voltage for the TPS at idle. Here is the major problem-cruise contol is now at runaway-I set it and its speed increases about 15mph over its setting-so what do I do to correct this-any and all help would be appreciated-always-thanks in advance!
