CT Coffee Nites '06 Check in on what's happenin'
Possible Northeast TDR dyno day, lets set it up.
OK tim were sorry
Signal73 said:
Got it all at the depot. Magnetic trailer lights included so dont bother buying those ;) Probably will start tomorro, will try to rig the engine hoist to do the heavy work...
Do I have to sit here in suspence again, I'm still waiting for AJ's photo's. What are you working on Jim?..... Gonna paint the frame on your 12 valve? I need to start painting some underbody stuff before they rust away.
Warpig said:
Do I have to sit here in suspence again, I'm still waiting for AJ's photo's. What are you working on Jim?..... Gonna paint the frame on your 1st gen? I need to start painting some underbody stuff before they rust away.
Jim when did you get a 1st gen? I need to do my fuel sending unit one day and run some new rubber lines. I might just drop the tank down instead of lift the bed. It's not too rusty under there suprisingly.
Matt, you might try taking out the 4 left side body bolts and loosening the 4 right side ones so they're just caught and using the engine hoist to tip the left side of the bed up enough to do what you want to the tank.
I want to be able to remove the old brake line that is between the frame and tank and secure the new one anyways.
Also I want to set up a day a DEZ racing for some dynoing. Im putting Methanol in this week so I will want to see which nozzles work the best. Let me know if anyone is interested.
Not sure when the Dyno will be done, But a friend of mine in New haven is in the prcess of installing the same dyno that Janettys has. When it is all done I am going to try and arrange a dyno day!
Sounds good Mike. Let us know.
Ha,ha, I meant to say 12 valve :{
Wow Todd, never seen one of those before!
Tim you guessed it. Wanna get it under control before it gets any worse... .
Millertim(e) how that truck running now? Looks like you got everything in... .
AJ, Black rims chrome centers and that dooley will look bad ***.
Hey TnL will the dyno be located right in New Haven? Is there a completion date?
It's almost as easy to drop the tank than it is to lift the body, tank straps are relitivly cheap from DaDealer, Jim what you workin' on, I might have some free time the week between X-mus and New Year :confused:
Hahahaha, look at the install instructions :) looks kinda like a pain in the butt, hey but you guys said the leveling kit was easy also :D 2 brake lines and 2 calipers later its all set :-laf
Ok guys I am going to go and check out the Dyno this week sometime. It is finally up and running, and one really cool option that they installed is the 1/4mile simulator complete with X-mas tree Starting, I will post all the particulars once I have them!
