CT Coffee Nites '06 Check in on what's happenin'
Possible Northeast TDR dyno day, lets set it up.
OK tim were sorry
Dealer?
PRattenbury said:
Nope. where do I gotta go to get them? Dealer?
The dealer should have them, Cummins Metro Power definitely has them.
Maybe we should take up a collection, say $20. 00 each and order up a bunch of common gaskets, seals and such. Then either replace them as they are used or reimburse the Kitty as you use them :cool: The trick is to figure out what we should stock. Light bulbs for marker, tail lights, ect would also be a good Idea too.
Paul if you make a trip to cummins, let me know i may have you grab me some stuff if you dont mind...
Dan, if you see this and are coming down on fri, shoot me a PM maybe ill have you grab the stuff. Freeze plugs. there cheap...
And make dang sure you put the oil return fitting on the new turbo BEFORE you mount it. So you won't be like me, and have to take it back off and do it twice. Also might be a lot easier to remove the whole manifold and mount it that way. Another tip, cover the battery terminals while you are leaning over them. Advance Auto parts has a $20 step that hangs on the front tire to stand on, makes work under the hood a lot easier, and it don't slip, much safer than other methods.
I've heard about them bearings. I think I seen some new sealed units on EBay. Maybe I'll get one or two. You can kinda hear it in the exhaust when they start going bad. :rolleyes:
We should get a group buy going on those muffler bearings. Or maybe we could all chip in like Moose said and keep a few at the shop. I'm going back to see if they sell any blinker fluid.....
guys my my dad is taken my truck so i need to put to stock. turbo. exhaust intake all but my injectors cause i dont have them do you think it will cause a problem. i wanted to leave the exhaust but he wants it quiet
