CT Coffee Nites '06 Check in on what's happenin'
Possible Northeast TDR dyno day, lets set it up.
OK tim were sorry
Good Stuff!!
Signal73 said:
Moose, Check this out: clicky here :cool:
Just what the Moose was looking for. The Pan has a leak at the gasket, So why not change the fluid and adjust the bands. :cool: I have the #40 Torx, But no Sm In-lb Wrench. I could check the calibration, But We are on still out at work :-{} ! I like that Smillie, It fits!!
Is anyone still collecting waste engine oil? I have 4 Gallons of gas engine oil, can take it to the dump or bring it on down. Moose00 Oo.
i'm pretty sure tool man or mark have the right inch lb torque wrench. . as they both drive autos, i have it and could bring it over . . if they don't . . let me know
thanks
Deo
yup, got one Bob...
I have to run up there on lunch today. "IF" I remember to grab it, I'll give ya a call and leave it out with the greeter here.
Mark, Hang on to it. I plan to do that job Friday night, as I did it once a long time ago, as in a 727 in the 1st gen ;) Also, I can't get to the Torque Tester as it's in Uncle Igor's shop, and I am Moose-non-grata down there, for now #@$%! Deo, can use Mark's and or Signals 73's Thanks Hehe :) Moose00
<BR>
<BR>
Alright, stop bragging about the size of your <Font color=blue size=7pt>tillers</font>... .
<BR>
<BR>
AJ, is the tiller black????? :D
Sounds good, if I can use it in a few weeks that would be great. Probably Easter weekend if the weather is good...
:eek: :-laf . . its actually red. . its called a Mantis. . it works really well though. . you can have it whenever you need it.
Check this out, cause this is exactly what it is, and you'll be able to tell if it will work for you! http://mantisgardentools.com/home.asp
Rider's Rides
JLEONARD said:
Sometimes???? :-laf
J, Isn't time to be back in "Today's Featured Rig?" :-laf :-laf :-laf
In seriousness, I want to do that transmission Adjustment Friday, as my pan gasket is leaking. :{ I am planning on getting a NAPA filter and gasket by then. I also have ordered a do-hickey to put a drain in the stock pan. Were would the best place to put it in the pan, IE forward or back corner. If I can figure that out, then I'll stick The hole in the pan to drain it out before droping it. Moose00
