CT Coffee Nites '06 Check in on what's happenin'
Possible Northeast TDR dyno day, lets set it up.
OK tim were sorry
You actually got everything back functional again. My cab lights still don't work! Plus, I got my line of fire and 3rd brake lights to install, and the tail and headlights will be here before I know it. Then there's the turbo, the headliner... . am I forgetting anything? Oh, yeah, the new tailgate, air horns... . AAAAARRRRRRGGGGHH!
Signal73 said:
Hows the carb run?
Really good at idle and I've got the top end running nice and smooth. Mid range is another story. I'm good till 2500 and then it acts like it is starving or sucking air, after a few seconds, it smooths out.
Guess I'll just shell out the 650 for a new one and be done with it.
Mark, Think its the screw looking thingy we saw after it was all together?
Paul, You need to start working the night shift on that truck!
Nope, the only adjustment needles are on the front of the carb. One was at 5 turns out and the other was at 7. The directions said to set them at 3 turns. Pretty sure it has something to do with that.
I was by myself all day down there and it a real PITA to make adjustments and drive the boat.
Now that the carb is clean and adjusted, I need to make sure the timing is set also. Then start messing with the needle valves.
