culmination of driveline vibration
front springs
Fastest automatic
Hope this helps someone: About 10K miles ago my truck developed at vibration at 41-44 mph. It was definately not in front end;no steering wheel shake. I rotated & balanced the tires, no change-took truck to tire dealer for balancing-no change- Talked to servicing dealer--"sounds like tires". Discussion not helpful!! When servicing trans we found one broken bolt at rear u-joint. Thought this was vibe. replaced broken bolt. Nope. About 2 weeks ago I stopped for fuel. When shifted into reverse It sheared the other three bolts at this u-joint! You can imagine my chagrin at seeing my Ram being toewd in by a Pford! After reminding service manager that Chrysler would have to prove that mods caused problem, the MoPar extended warranty replaced the joint, & the driveshaft. End of vibration!It is my understanding that "driveshafts get replaced" with some regularity. (no proof)
Jim Humphrey - Cedar Creek, Tx.
'99 2500 QC, White/Driftwood, Tan Lthr, Grovers, Blk WeatherGuard Inside bed box, MAAG Boards, Alpine 6 Disc CD, 3-pc. bug shield, 4x4 Mudguards, Line X over the rail,15. 5k Pull Rite 5th hitch. '01 Tow/Flip mirrors, Tow a 29' Alpenlite w/1 slide every time I can.
mailto:jenjim@Impala.net
[This message has been edited by Rd. Runnr (edited 04-03-2001). ]
What mods where they tring to blame the drive shaft problem on?
99' Qcab, 4x4, auto, chrome nerf bars, VA, Boost elbow, DiProcal Pillar mount gauges, 16X8 Eagle wheels, Dunlop 285/75 AT's
