Hello
I talked to a Cummins tech one that works for Cummins
he said that the 07 ctd will have stainless steel lines and the pumps will be compatable with biodiesel fuel the 06 and older are not as compatable the problem with the fuel is the lye that is used in the making of the biofuel.
lye is very hard on steel lines they are changing to stainless steel.
so with this info one might not want to make a biofuel unit with black steel pipe fittings (as most of the appleseed unit's tell you to use) /brass (not copper) will work just fine but stainless steel would be the best.
running blended fuel (dse, ect) is not the same as biofuel it has it own set of problems.
cj hall
cj hall
