I recently upgraded my '99 by adding some power for towing. Unfortunately, the truck hasn't run right since. Over Easter weekend, I installed 4" exhaust, Piers 35/40 hybrid turbo, DD Jammer 3 injectors, and AFE intake. I had an Edge EZ already. After getting all the parts on the truck, I took the camper for a weekend trip. I immediately noticed a engine miss under load, and the engine misses sporatically when warm. It doesn't miss when cold. After talking with a dozen or so "experts", and replacing a few parts to no avail, I decided to have the local Cummins shop diagnose the problem, before I threw any more money at it. I also have low boost for what was expected (30psi peak), and low EGT's (1200 max), and did not get a dramatic increase in power that I expected.
Cummins had the truck for a few days, and I called and they wanted to put it on their dyno for further test. I agreed, and arranged to be there for the test. After 4 hours on the dyno, they gave up and decided that it was LIKELY to be an injection pump. They also thought I MIGHT have an injector problem and that the Edge EZ COULD be causing some problems. This was due to the reaction they got when the edge was disconnected - no miss on the dyno. The final verdict was a "No Problem Found"
on the paperwork and a bill (they did cut part of the cost, since they couldn't give an answer). I have now ordered a pump (Thanks to Rip
), but still do not know if that will solve the problem.
IS THERE ANYONE OUT THERE WHO CAN TRULY DIAGNOSE A VP44!
Jeff
Of note - Dyno reveiled a 40HP increase without the Edge EZ, 59HP with, from bone stock.
Jeff
