Engine/Transmission (1994 - 1998) cummins conversion into 97 v10 questions.
Engine/Transmission (1994 - 1998) Governor lever adjustment screw
Engine/Transmission (1994 - 1998) Keeping an HX-35 alive
I am doing a cummins transplant into my v10 the truck is a 97 and the donor is a 94, i am worried about the plugs going into the body harness, the 3 plugs if your looking at the front of the truck they are on the right side. they are different on both trucks. i am wanting this conversion to be proper (nothing on switches) like the grid heaters and the fuel shut down solenoid. what should i do? Thanks
My guess is that you will need to use the wire harness and PCM from the donor truck.
Many on the leads from these 3 plugs go to (or from) the PCM including: Auto shutdown switch, veh speed sensor, tach, wait to start, water in fuel, a/c relay, MIL, grounds, OD switch, PCM 12v, stop lamps.
Hope you have the factory manual with the electric diagrams.
