I had the problem for 20,000 miles.
I took it in at about 5000 miles and the dealer that I bought the truck from told me it was normal. I was not impressed with the service department there, so I took it to another dealer. They did an injector kill test and found a bad injector. Dont let them tell you that it will take 2 days to do the test. It only took this dealer 20 minutes. It was loudest at full operating temperature after driving down the highway for at least 30 minutes. I told them it needs to be checked as soon as I get there or it might not be detected. It worked, I called them the day before and told them I will be there first thing. They checked it right away. Bad injector. Now the wait. 10 days for the new injector to arrive. At least I could still drive it.
After theyinstalled the new injector (about 30 Minutes). The problem was NOT fixed. needless to say I went in 2 more times and 2 more injectors were replaced over the nect 15,000 miles. (I dont like going to the dealership so I was not in a huury to go right back). on the 4 the trip they tried an injector cleaning with some recycling machine and some additive that I needed to run a tankfull of fuel to complete the process. No change. Still knocking.
On the next trip they did a injector kill test and another injector was ordered.
When it was done I noticed the paper work listed 2 parts installed under warranty. One was an injector, and one was a pushrod. I called them after I got home and asked them if they put someones part on my paperwork and they said NO. one of my pushrods was bent and they replaced it.
I had the Knock for 20,000 miles no matter what gas I used from all over the country and it seams like the whole problem was a pushrod.
7,000 since the repair, and no more problem.
The sound my truck made before the pushrod replacment was the same sound that was put on this forum as a sound bite. (Maybe it was the other forum). Anyways the sound and conditions were the same as many have indicated. Ticking sound at idle, Mainly while in gear, Engine warm, with some noise when the auto trans shifts into a higher gear.
Might want to look into bent pushrods.
