check it out as if you didn't know http://www.cummins.com/na/pages/en/mediaresources/marketspecificnews/subjectpressrelease. cfm?uuid=000704DB-9522-1AE9-846280C4A8F00000
1997 Dodge Ram 2500 HD / Club Cab, Cummins Turbo Diesel (silencer ring removed), 4. 5" Skyjacker class II Double Flex suspension lift, 36x14. 5"x16. 5" Ground Hawg radial tires on 16. 5x9. 75 Weld Super Singles, dual steering stabilizer, 4. 10 gears, 33-tooth Speedo gear, Psycotty Air Induction, Mag-Hytec rear, Amsoiled bumper to bumper, JRE 4" Turbo back exhaust, Rhino liner, Extang Black Max, Grizzly double bent nerf bars, Bushwhacker exstenda fender flares, Kanduco Sweet Tooth grill insert, Confer super skid axle truss, DT Trac-bar, Moog tie rod system, Fabritech stage II traction bars, Energy sway bar bushings and end links,CATZ hyper-white (stock location)GTS headlight black outs, Lund Eclipse side window. Truck Pic's
