Cummins head stud prices are ridiculous
SMARTY high idle @ 80*
Bully Dog- Torque Dog On A Stock Automatic??
I'm in the same boat to. I just ordered my Juice with Attitude.
I won't be able to "use" all the power until I get the studs and
a new head gasket. My truck is just a puller but I do like
to waste the kids in the imports once in a while for that
feel good feeling. hehehe
Unless you have a different turbo and injectors you still wont have to worry about the "Use" of all the power without studs and head gasket. ;)
I am over 500 hp and have sled pulled several times and run ricers plenty all on stock bolts and gasket yet, but my wastegate is set at 45 but unless I run on level 4 or 5 I rarely get over 40 psi boost. I am usually way past them at around 35 psi boost on level 3 smarty sw6. :eek: I would like studs too but I want to see how long the stock gasket will last with stock bolts the way I run it. When it does go I will o-ring and stud but not until then and then set the wastegate to around 50psi.
I've heard countless times that the boost pressure isn't what kills the gaskets, it's the backpressure of a small exhaust housing. (stock charger)
which ever is HIGHER intake or exhuast . most only measure intake ,drive pressure is then a mistery and with too small a housing it can easily exceed boost pressure. so a wastegate at 40 psi can have a drive pressure of say 50 psi and take out ur hg. and the bigger the hp the quicker/higher the boost/backpressures become . nos is also a big factor as it becomes more common. adding substantial drive pressures without increasing boost #s. hence why drive pressure is so important to head gaskets. the fact is if ur crossing your fingers you should also be ordering the replacement/upgrade parts. sooner or later you'll need em! :)
Hey IC SMOKE
So what I am getting is that once you O-ring and head stud you will never blow a head gasket ?
Nobody out there with studs or O-rings or both, ever blown a gasket ?
At twice the price studs would be worth it.
If everything on these trucks was that easy.
On my 3rd lift pump, 3rd injection pump and so on.
Not trying be a smartass, but I am pretty sure 1 of the 800hp plus guys is still on stock bolts. Sound like anyone ?
Just my 2cents.
Scott
After surfing here on TDR and hearing/seeing guys blow headgaskets after upping the power with a big single or twins I thought it would be wise to tear the truck down over winter and have it O-ringed. you CAN blow out a O-ring but I havent seen one. Its money well spent IMO! a buddy here on TDR "Dispatch" bought my HX40 and blew a headgasket... . with a blown HG I woudlnt want the mess of cleaning coolent out of the oil or oil out of the coolant!!!! just something to consider!
Ian
Boost and backpressure are part of the equation of cylinder pressure. A good example is a 12v that advances the timing (no other changes) and now blows a HG. The cylinder pressure went up due to the advanced timing... . Same hold true with running nitrous, add nitrous to a truck that has no o-rings/fire-rings and watch for the HG failure, even if boost and backpressure are the same (use of a good wastegate will allow for this).
Bottom line is boost and backpressure do factor into HG failure but the cylinder pressures is what ultimatly causes their demise. We use backpressure/boost pressures as a reference because we can measure them easily... .
well said! its just money and Ill gladly pay the 400 since I DO NOT want to do a head re-moval again!! I didnt pull my head due to a blown HG, I did it to O-ring the head and stud it so it was mearly a saftey precaution so to speak.
Ian
Just because you stud & o-ring it doesn't mean it'll save you. I'm going on HG #5 now with only 45 psi... #@$%!
when you o-ring a head, your just have grooves cut in the head for a metal/wire o-ring that puts more clamping pressure on the headgasket around the cyl. , right? Theres no machining of the block involved, correct?
correct! All machining is in the head.
3 retorques here,
go easy on the truck until you have done the 3 retorques I dont remember how many heat-cycles it takes but it takes a lot
so far 60lbs and the rings are holding:eek:
Ok guys I've been gone for quite a while. Just lost head gasket Friday night. I was towing around 6000lbs and about 40 psi boost. I got oil leaking out of the front of the head. So I heard there is a better gasket to get? Can you give me the part number also I'll be doing studs. Felt violated with the truck on a trailer and a f**d towing it LMAO.
ROTFL!!! I know exactly how you feel.
When I had to be towed a F#$D flat bed picked me up.
I actually thought for a minute about asking for another
truck like a Petebuilt or maybe just pushing it the 75 miles.
LMAO, I took the pictures first so my friend couldn't give me a bad time about it LOL, all in good clean fun. In the end I was thankful they were up there and watching my back. Even though they do drive fords and chevys LOL.
