HTML:
you can't take an OTR (Over The Road) engine and just slap it in a boat
Yes you can. This is done often. There is a company in Texas that sells the parts necessary to marinize a Dodge CTD.
www.hsmarineservices.com
Check them out.
HTML:
Depending on what you put it in, it could be the wrong rotation also
True, but if the boat is a straight inboard, this is easily dealt with. ALL the modern marine trannys can be used in either rotation. In other words you can put 2 standard rotation engines in and have counter rotating props.
When I re-powered mine with a single standard rotating Cummins I removed a counter-rotating Perkins diesel. I replaced the transmission with a modern one (wanted all new) so I could still use the RH prop I had.
Converting a gas engine boat to diesel is a nice project but it does require some extra thinking... . you need to make sure the prop shaft, transmission, etc can handle the extra torque/hp. That also probably means a larger diameter prop, so you may have to lower the shaft to get clearance to the hull.
If you are serious bout doing this I suggest you poke around in
www.boatdiesel.com It is an awsum site for marine diesel knowledge.
If you need help along the way feel free to e-mail me at -- email address removed -- and I'll try to help.
I can also give you the formula for figuring shaft diameter.
Sounds like a nice project. Good luck.
