Cummins in chevy Bellhouse Adapter
anybody on this board? 81 FSJ
12Valvie Into a Ford
The auto set up runs about $675. 00
The manual set up $750. 00
Plus you'll have ship to add as well ,somtimes you can get these cheaper ,you'll also need to make sure you get the right starter because the not stock GM or Cummins .
prices are coming from past sales and parts are getting hard to find,and they are no longer made.
things to look for are you getting the bolts,brackets,ect.
Here is a question... if you are wanting a manual adapter... other than the fact that you may already have a manual transmission... wouldn't it be MUCH easier to just run a dodge unit??? A NV4500 will fit into pretty much any vehical and you also get the larger imput shaft than the GM unit has. I dropped a NV5600 into my 89 CK style and it fit great without the use of a body lift!
Just a thought... RyanB
