Archived Cummins only idles!
Archived froze up/locked down???
Archived BigDig NEEDS HELP STUCK IN VIRGINIA!
Left from a stop sign, check engine light comes on, truck won't accelerate, only idles. Stuck on side of road. Any ideas?
After shutting truck off for about 20 seconds, put pedal to the metal 3 or 4 times... now it accelerates somewhat, but check engine light still on. Ideas anyone?
Maybe the APPS sensor? What codes are you getting? Could try unhooking the batteries for 15 minutes and then recalibrating the APPS.
Dan
You need to find out what those codes are. It sounds like it went into limp mode.
Key off, on three times and leave on, watch odometer window for codes.
P1693 and what else?
. . fyi. . Here's my experience with replacement of APPS/TPS on my 98. 5, 24 valve diesel at 150K miles.
Initial diagnosis - $69
Replacement of APPS
APPS (Parts) $398. 95
Labor $60x1. 25 $ 75. 00
Waste Disp. Fee $ 3. 00
Shop Supplies $ 3. 00
Shipping/Handling $ 21. 88
Tax $ 33. 16
TOTAL $534. 99
TOTAL COST... ~$605
I've got the old part but don't know if it is easily fixed. Anybody try this? Guess next time, I'll know the symptoms & fix this myself for about $400.
BTW, the symptoms were... . at low RPM's/minimal throttle, engine speed would go to idle for about 5 seconds. Finally, after moving the throttle back & forth, the engine start responding again.
Check here for a good price... to compare against your local Dodge dealer or Cummins dealer. Dodge dealer will have highest price, most likely.
http://www.cumminsstuff.com/
P0121 (M) Accelerator Position Sensor (APPS)
Signal Voltage Too Low
APPS voltage input below the minimum acceptable
voltage
(M)= Malfunction indicator Lamp
