cummins PT# for turbo, oil drain gasket
Crazy Wiring
4X4 Brake Pedal Mushy Creep.
hey fellas,
dose any one know what the part number for the gasket inbetween the turbo and the oil drain tube?
poped the hood to check the oil tonight when the wife got home, and was a qt. low. witch i am never a qt low. well started looking around and noticed a oil spot under the turbo. sure enough, its leaking out of the drain tube. going to put some hi temp sealant on there tonight. but if any one knows that part# it would be great. this is for the stock turbo.
bob
I bought myself some gasket making material and made myself several, I got the material from Napa, I believe it was 1/16th thick and rated for 300 deg F. Plus a single sheet will make quite a few gaskets, just my 2 pennies... ...
