Fuel and Lube Oil Blending
Two recent rulings by the United State Environmental Protection Agency effect the practice of blending lubricating oil with diesel fuel. First, on 10Sep1992, the Office of Solid Waste of the United States Environmental Protection Agency determined that used lubricating oil was not classified as hazardous waste. In addition, the blending of used lubricating oil with diesel fuel for burning in diesel powered vehicles was determined to be an acceptable method for disposing of used lubricating oil (57 Federal Register, P. 41583, 10Sep1992). Note, state or local regulations may prohibit the blending of lubricating oil with fuel, check state and local regulations. Second, beginning 01Oct1993 diesel fuel used in motor vehicles, as defined by the EPA, in on-highway applications must contain less than 0. 055% sulfur by weight (Mandated in Section 211 of the 1990 Clean Air Amendments; 57 Federal Register, P. 19535, 07May1992). Fuel blended with lubricating oil must also meet this specification.
Cummins Engine Company allows the blending of lubricating oil with fuel used in their engines, except those equipped with an oxidation catalyst, often referred to as a catalytic converter (e. g. 1994 M11's used in transit buses, and 1994 B's and C's used in automotive applications). Cummins Engine Company permits a maximum of 5% used lubricating oil to be blended with fuel. This helps to reduce operating costs and aids in the disposal of used engine oil. The blending of new lubricating oil to raise viscosity is also permissible. This helps to increase the viscosity of lighter fuels to acceptable levels. These practices are outlined in Service Bulletin 3379001-05.
Cummins Engine Company's recommendations for the blending of lubricating oil with fuel used in its engines have not changed; however, if blended fuel used in motor vehicles, as defined by the EPA, in on-highway applications exceeds the maximum sulfur content, federal law has been violated and penalties can be assessed. To insure that blended fuel complies with the law the following procedure must be followed. Both the diesel fuel and lubricating oil must have their sulfur content measured by a qualified laboratory using the testing method specified in ASTM D2622 (American Society of Testing and Materials Standard). Using the values for the sulfur contents of the fuel and oil find the appropriate blend factor from the table below. Once the correct blend factor has been determined multiply this by the volume of fuel to be blended, the result is the amount of this oil that can be blended with this fuel and remain within legal limits.
Blend Factor Table
To determine the blend factor, locate the column in the table that corresponds to the sulfur content of the fuel, then find the row that corresponds to the sulfur content of the oil. The correct blend factor will be the value at the intersection of the row and column.
Lube Oil % Sulfur By Weight Fuel % Sulfur By Weight
0. 005 0. 010 0. 015 0. 020 0. 025 0. 030 0. 035 0. 040 0. 044
0. 10 0. 612 0. 536 0. 459 0. 383 0. 306 0. 230 0. 153 0. 077 0. 015
0. 15 0. 321 0. 281 0. 241 0. 201 0. 160 0. 120 0. 080 0. 040 0. 008
0. 20 0. 217 0. 190 0. 163 0. 136 0. 109 0. 081 0. 054 0. 027 0. 005
0. 25 0. 164 0. 144 0. 123 0. 103 0. 082 0. 062 0. 041 0. 021 0. 004
0. 30 0. 132 0. 116 0. 099 0. 083 0. 066 0. 050 0. 033 0. 017 0. 003
0. 35 0. 110 0. 097 0. 083 0. 069 0. 055 0. 041 0. 028 0. 014 0. 003
0. 40 0. 095 0. 083 0. 071 0. 059 0. 047 0. 036 0. 024 0. 012 0. 002
0. 45 0. 083 0. 073 0. 062 0. 052 0. 042 0. 031 0. 021 0. 010 0. 002
0. 50 0. 074 0. 065 0. 056 0. 046 0. 037 0. 028 0. 019 0. 009 0. 002
0. 55 0. 067 0. 058 0. 050 0. 042 0. 033 0. 025 0. 017 0. 008 0. 002
0. 60 0. 061 0. 053 0. 046 0. 038 0. 030 0. 023 0. 015 0. 008 0. 002
0. 65 0. 056 0. 049 0. 042 0. 035 0. 028 0. 021 0. 014 0. 007 0. 001
0. 70 0. 051 0. 045 0. 039 0. 032 0. 026 0. 019 0. 013 0. 006 0. 001
0. 75 0. 048 0. 042 0. 036 0. 030 0. 024 0. 018 0. 012 0. 006 0. 001
0. 80 0. 045 0. 039 0. 033 0. 028 0. 022 0. 017 0. 011 0. 006 0. 001
0. 85 0. 042 0. 037 0. 031 0. 026 0. 021 0. 016 0. 010 0. 005 0. 001
0. 90 0. 039 0. 034 0. 030 0. 025 0. 020 0. 015 0. 010 0. 005 0. 001
0. 95 0. 037 0. 033 0. 028 0. 023 0. 019 0. 014 0. 009 0. 005 0. 001
1. 00 0. 035 0. 031 0. 026 0. 022 0. 018 0. 013 0. 009 0. 004 0. 001
As an example consider 50,000 gallons of fuel with a sulfur content of 0. 04% by weight and lubricating oil with a sulfur content of 0. 5 by weight. Using the above table results in a blend factor of 0. 009. Multiply this by the amount of fuel to be blended:
* gallons of oil that can be blended = 50,000 * 0. 009
* gallons of oil that can be blended = 450
Therefore 450 gallons of this oil can blended with 50,000 gallons of this fuel and remain within legal limits for sulfur content.
The values in the blend factor table have been calculated to account for differences in fuel and lubricating oil density and measurement error. Due to the accuracy of the test for sulfur content it is not safe to blend lubricating oil with fuel that has a sulfur content above 0. 045 percent by weight.
Copyright© 1994 - 1997
Cummins Engine Company, Inc.
All rights reserved
Blend Factor Table
All rights reserved
