JSpecht said:
Where can I find alist of the pump #'s and spec's on the pumps to know if I found one that will work???
One place is the Cummins Master Repair Manual for Injection Pumps and Injectors Mid-Range Engines, Bulletin Number 3666037-5, printed in 2000. For each CPL, it lists the various pumps that will work.
For CPL 1351, the following pumps are shown:
Rating TQ/RPM VDC Cummins Bosch Timing HiIdle/NoLoad
160@2500 400@1600 12 3923346 0 460 426 205 1. 25mm 2800/2900
160@2500 400@1700 12 3923347* 0 460 426 205 1. 25mm 2800/2900
160@2500 400@1600 12 3923348 0 460 426 204 1. 25mm 2800/2900
160@2500 400@1700 12 3923349* 0 460 426 204 1. 25mm 2800/2900
160@2500 400@1600 24 3918964 0 460 426 186 1. 25mm 2800/2900
160@2500 400@1600 24 3918992 0 460 426 184 1. 25mm 2800/2900
160@2500 400@1700 24 3919713* 0 460 426 186 1. 25mm 2800/2900
160@2500 400@1700 24 3919715* 0 460 426 184 1. 25mm 2800/2900
* = Remote KSB
There's other detail in the booklet. Nice to have. Covers VE and P7100 pumps and some others that don't apply to us Dodge owners.
It also has a section of pump part numbers that can be built from other older part numbers.
Regards, DBF
