Have seen lots of threads on Geno's Cup Smoothie vs the console
latch. Lots of solutions - lots of (minor?) problems!
Yes - I have one. Yes - best addition to the truck!
But . . . . in spite of the directions, had problems latching.
[Looks like everybody does]
Some have "modified" the plastic on the smoothie,
some "smack" the console lid to get it to lock.
Some have given up on latching - if they never flip the console up
for a 3rd seat in front.
I had a bunch of those same problems -
including the one where it locks and won't open!
Think I have if figured out . . . finally.
1. Shim the latch like the instructions indicate. I used one fairly thick
washer under each screw.
2. Remove the "rubber snubber" that's in the console lid just to the rear
of the latch (it just pulls out).
3. Here's the "biggie". Having done numbers one and two above, thought
I had it made. Seemed to work great. Then the *#@^&* thing wouldn't
open! After lots of pulling, wiggling, (etc. ) it would open. Tried pushing,
pulling, smacking , too. Couldn't figure out why sometimes it would work
great - but twice stayed locked up tight - then suddenly open.
Took the latch out to figure if I did something to it when I shimmed it.
Theres a small "concentric" - looks like an uneven triangle - it's in
the opposite end of the latch mechanism from the handle - moves
freely (it's loose to "swing" back and forth).
When the latch is horizontal - console lid down - it should hang free.
When the latch is up (vertical) it blocks the latch from opening by
contacting the end of the metal latch "box".
[I guess intended to keep kids? in rear seat from opening the console
when it's in the "up" position, spewing the contents in the back seat area].
For some reason it get's hung up in the "block" position and won't allow
the lid to open . . doesn't seem to have anything to do with the Smoothie.
So - for number 3 (finally) - take a bit of weatherstrip adhesive, glue,
whatever - and glue that critter to the position it's in when the console
- and the latch - are in the down, horizontal position.
Probably should add this was on an '05.
Geno's . . . . are you listenin??????
JC
JC
