I have had a 96 and 01 2500, 03 and 14 drw 3500s. I rotate tires every 5k miles. The only problem I had was with the 96 2500. In the first 2,000 miles I had three sets of steel rims and two sets of tires after the first set had cupped. Vibration was the problem being chased. I finally bought a set of Micky Thompson aluminum rims and had no further problems. The second set of tires were changed after 55,000 miles. The problem with the factory rims can be explained by the attempts at balancing. The balance machine mounts the rim using the center hole which assumes the hols is indeed centered and the runout of that hole matches the runout of the outer beading surface of the rim. No other problems with 600k spread over the four trucks. Hope this helps.
I see I need to update my sig. The 14 truck now has 30k with 12k towing. It has the Alcola rims and I only rotate the front tires side to side. No uneven wear so far.
