Going to Fl on the 19th of the month to get my R&R.
But I think Scott meant R&D is never done... I'm an engineer... I know!!
Here's my misunderstanding of the significance of the fuel pin profile... hey somebody might as well give it stab... .
We have mechanical fuel delivery systems. The fuel pin profile is intended to deliver fuel based on a certain level of air (turbo boost), and at certain rpms. The stock pin intends to balance this in the form of a specific power curve based on stock components.
The DD pin was designed several (or many) years ago based on known information at the time. It was probably a nice improvement at the time when there were few injector upgrade options, and maybe few or no turbo upgrade options.
Today, as you know there are many injector AND turbo upgrades available. So I think Old Smokey and PDR are trying to upgrade and modify the profile based on the availbility of items like modified turbogharger options, EDM injectors, 3200 rpm gov springs, etc. This will yield a different power curve. And all in an attempt to keep smoke levels down as environmentally we are in a different era today.
Also the stock fuel pin is ground eccentrically, so travel can be limited because of the thin "neck" center section. Old Smokey is more than likely made to be unidirectional so it can have more travel becuase the upper and lower sections are held together at the back edge, not near center.
With the new electronic engines a simple program box accomplishes the changed power curve... . and they are all a little different too... . they all work, but they too yield different results depending upon other mods.
Am I generally in the ballpark here?
Jay
