Custom fan sources
TAG (Turbo Air Guide) How do you like it ?
BD Govenor kit
Does anyone out there know of anyone other than Flex-a-Lite that could make me a custom cooling fan? I am needing a fan ASAP. Thanks.
Yea, I guess I should have been more specific, I was able to get a different Cummins fan hub assembly that places the fan centered above the harmonic balancer, also doesnt have the protrusion the normal 24 valve pulley has. It does have the threaded snout for a O. E. fan clutch. The issue I am having is that I have about 3/4-1 inch clearance from the cluth to the radiator (this is good) but I am needing a fan whose blades dont stick back farther than the 4 mounting holes on the clutch.
Picture this... 1111111______1111111 with the fan clutch being in the middle and on top of the dashes and the threaded piece sticking out the bottom of the dashes. So to answer your question, belt driven. I am hoping someone knows of a place that can make a fan. I talked with Flex-a-Lite today after seeing custom fans available on their web site but all they can do is custom bolt patterns, no offset changes. Big deal, doesnt help me.
check with horton or kysor they make fan clutchs and fans for big trucks. I have a horton electric fan clutch on my 9812v I love it but I was told they stoped building them. they can build you a fan blade to fit!!!
