custom twins
A new GM Billboard for the Duramax...
91 Mercedes 350SD
ok so i want to rebuild a turbo i have sitting around and put it in as a twin. i also need all the plumbing and stuff to set it up. whos the best to go to?
What turbos are you planning on using. I Jason Burton at NW Customs makes a great fitting plumbing kit if your using a 35 or 40 with a 3B. Not sure what other kit's he might make but they're very reasonably priced and excellent quality.
Also as mentioned above, Rips has a pretty vast supply of misc. twins plumbing.
you need a larger bottom charger. i have a 35/40 hybrid over an s400 on my truck now that i am thinking about selling the piping for so i can build a larger set. it is set up with an pdr billet extreme external gate off the manifold. i runs great. i would use that 62 you have and put an s400 or a 3b below it. that would be a great setup.
Pick one or the other(35 or 62) for your top turob and sell the other... with your mods, you could probably use the 62 on top and throw an S400 on the bottom.
well my problem is lag my turbo doesnt seem to want to spool very well. i want to put the hx35 on top to help it. what if i where to do an sps66 on the bottom and the hx on top?
still to close in size and flow rate. you are on the right track, but go bigger on the bottom, 3b or s400, or ht60.
k lets go this way i want to put the stock turbo on top. possibly modified something like bigger exh houseing and different compressor. but lets talk in terms of compressor sizes the stock hx is what 42mm? so i want something thats 40s range on top and on bottom i want what low 70s?
now here is what ive been thinking about doing stock turbo top sufficent big one on bottom, head studs, injectors mach 4,5, or 6s edge ez and tst stacked. the goal is as with any twins is to have the quick spool. i want something stock or close to it if not faster and good air flow from the bottom one. head studs if i can afford it so i can actually use the boost thats able to be made(if i cant afford these then ill wastegate at 50lbs till i can) the 2 chips and the injectors. now as far as priority of what i want. #1 turbos #2 chips #3 injectors #4 studs.
i know ya'll wont agree but im working on a very limited budget and right now i dont even know what that will be exactly i wanna know what will be the ideal setup and work out the price of the project and go from there.
you will need a Ht3b or a S400 on the bottom of a 35 or a 62 (i would go with the 62 if it were me),... ... with that combo it will run around 60-65 psi of boost
you will need to O-Ring the head along with studs
Scott
Scott
i would but i want/need the spool of the smaller 35 cause this one is just too slow
HX35/14 cm gated housing on top and a K31 on the bottom. . I am running the HX35 on top with a BHT3B on the bottom. . Spools great on the bottom.
Rick
